Date/Time: Sat, 26 Sep 2026 07:59:47 +0000
Customize Keyboard Shortcuts
View Count: 813
| [2022-08-18 13:23:53] |
| User562957 - Posts: 58 |
Hello everyone, I didnt find the "Reset and lock" in the Global Settings and "customize keyboard shorcuts" when I´m with the mouse I click on the right side with the right of the mouse and there is "reset and lock" but I dont find it on charts I find everything else but the last thing is this do you know where I find it ? |
| [2022-08-18 14:51:46] |
| JohnR - User831573 - Posts: 338 |
I do not know specifically of a shrtcut, but on the CHART menu there is a LOCK selection, which can be checked or not. I uncheck the item, move / scroll the chart so it has the amount of open space on the right I want, then go back to the chart menu and check the lock selection Hope this helps, JohnR |
| [2022-08-18 16:45:57] |
| John - SC Support - Posts: 48028 |
There are no options for locking the scale within the Keyboard Shortcuts or Control Bar buttons.
