Date/Time: Sun, 16 Mar 2025 16:31:17 +0000
keyboard shortcut ?
View Count: 478
[2022-08-18 10:58:28]
User562957 - Posts: 58
Hello, everyone
i have a question if there is a shortcut for scrolling in the chart you can see in the picture that i can only move the chart with the arrows.
If i have a lot of historical data it slips far away. and when i use the arrows on the outside it takes a long time. is there a possibility to change that?
imagesierra chart.png / V - Attached On 2022-08-18 10:55:44 UTC - Size: 118.75 KB - 105 views
[2022-08-18 12:53:48]
JohnR - User831573 - Posts: 320
The ability to customize keyboard shortcuts is under Global changes. B U T -- There are already shortcuts for
chart page scroll left and page scroll right. shift left arrow and shift right arrow. There are also shortcuts to go to end of chart key = end by itself.
Goto Global shortcuts and scroll through the pop up to see all of the ones that are defined as well as the ones you can define or change keys around to your preference.
Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu)
Also you can use AutoHotKey - a keyboard macro program if you want to create some other more exotic / complex combination or actions.
Hope this helps.
JohnR
