Date/Time: Mon, 17 Mar 2025 03:44:42 +0000
Saving SCSS
View Count: 453
[2022-08-18 01:04:59]
User123235 - Posts: 46
Having trouble saving .scss file to data folder. I click on the link at the bottom of the indicator description and it only lets me save it as text. Thanks in advance.
[2022-08-18 14:09:22]
John - SC Support - Posts: 38678
How you save a spreadsheet depends on whether it is a basic spreadsheet (opened by selecting "File >> New Spreadsheet") or if this is a Spreadsheet Study.
For a basic spreadsheet, it is part of the chartbook that you open it in. When you save the Chartbook, you will then be prompted to save the spreadsheet and give it a name.
For a Spreadsheet Study, you need to enter the name of the spreadsheet that you want to save it as on the Study Settings in the Spreadsheet Name / DLL File and Function Name field. Then when you save the Chartbook, it will save the spreadsheet to that filename. Refer to the following:
Chart Studies: Settings and Inputs Tab >> Spreadsheet Name / DLL File and Function Name
[2022-08-19 01:11:16]
When I click on this:
SC1 see image
I get this:
SC2 see image
How do I save SC2 to data folder?
imageSC1.png / V - Attached On 2022-08-19 01:06:54 UTC - Size: 37.99 KB - 105 views
imageSC2.png / V - Attached On 2022-08-19 01:09:07 UTC - Size: 296.28 KB - 102 views
[2022-08-22 17:54:50]
Sierra_Chart Engineering - Posts: 18801
Right-click on the file name link, and then select the Save File command.
Date Time Of Last Edit: 2022-08-22 17:54:59
