Date/Time: Thu, 17 Sep 2026 23:37:57 +0000
Futures Fly Spread
View Count: 818
| [2022-08-17 23:00:57] |
| User841161 - Posts: 348 |
Was trying to chart a crude butterfly spread chart. 1*clv22-2*clx22+clz22, using the butterfly spread study. On Tuesday 08-16 at 20:00 Central, it looks like the spread got out of whack. Do you know what would have caused this on the chart. Should I be using continuous individual charts that the butterfly spread uses? Was wanting to possibly trade this spread but need a very accurate chart of this spread..
| [2022-08-18 13:15:56] |
| John - SC Support - Posts: 47930 |
What do you mean by "got out of whack"? Does the data from the original charts look ok? Have you forced a recalculation of the Spread study? You definitely would not want to use Continuous Futures charts, as that would change the front month contract and not give you the data you want from the "non-current" instruments. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
