Date/Time: Sun, 16 Mar 2025 16:28:54 +0000
Moving Sl/Tp at the same time
View Count: 501
[2022-08-17 22:36:40] |
Bibro - Posts: 11 |
Hello, is there a way how I can set an ratio (for example 2/1) and then both sl and tp move at the same time at the right ratio when I move one of them ? Example: I executed an order with an 1/1 risk reward ratio and then I move my tp 3 Points up and the sl also follows the tp 3 Points up, without having them to move separately. Best regards Jeremy |
[2022-08-18 13:03:15] |
John - SC Support - Posts: 38678 |
Refer to the following setting: Global Trade Settings Windows: Maintain Same Offset Between Target and Stop Attached Orders (Global Settings >> General Trade Settings >> General) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
