Date/Time: Sun, 16 Mar 2025 15:07:39 +0000
Question: Is there a study or Subgraph Drawstyle which labels the Timeline axis?
View Count: 597
[2022-08-17 21:15:08] |
HumblyTrading - Posts: 192 |
Hello SierraChart Team, I hope you can point me in the right direction. I am using "Time Range Highlight - Transparent" Study to identify the starting candle of the Asia and NY range. Currently, I use the Draw Style "Color Bar Candle Fill," so that I can subtly change the color of the candles to easily analyze the timing of the chart. What I would prefer, if possible, is to have a small label or text at the bottom of the chart along the timeline axis (perhaps a diamond or triangle), which appears at each of the columns where that candle would be highlighted. Thank you for any help, Mike |
[2022-08-18 14:05:12] |
John - SC Support - Posts: 38678 |
There is not a study that will put the information along the bottom of the chart. This could be done using a custom study. Refer to the information for custom studies starting here: Advanced Custom Study Interface and Language (ACSIL) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-18 15:07:23] |
User431178 - Posts: 614 |
Here is an example of one way to do this using built-in study. Not exactly 100% what you asked, but maybe it is useful. |
[2022-08-19 12:53:50] |
Thank you very much for posting that! I will try this out in the coming few days. At least it gives some hints to get me closer. Happy trading! Date Time Of Last Edit: 2022-08-19 12:54:35
