Date/Time: Sun, 16 Mar 2025 13:58:18 +0000
Hi I need to figure out how to show the dollar amounts on my trading dom and not the point
View Count: 430
[2022-08-17 19:49:18]
User893516 - Posts: 13
my next question is how can i put a stop on the trading dom thanks
imagedom.jpg / V - Attached On 2022-08-17 19:48:54 UTC - Size: 81.58 KB - 115 views
[2022-08-17 20:01:43]
John - SC Support - Posts: 38678
The setting that controls the display of Profit and Loss is the following:
Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu)
We are not sure what you mean exactly about putting a stop on the trading DOM, but if you want to add a Stop to your main order, then that would be an Attached Order. Refer to the following:
Attached Orders
Or, if you are wanting to place a Stop as the main order, then you need to change the Order Type on the Trade Window. Refer to the following:
Basic Trading and the Trade Window: Main >> Order Type
