Date/Time: Sun, 16 Mar 2025 15:10:18 +0000
Question on scaling in and out of positions
View Count: 437
[2022-08-17 17:26:37] |
User982071 - Posts: 3 |
Also, I am having some issues scaling in and out of orders, for some reason the fill with the best price is the first to close, for example, if a buy 2 contracts, one at 4125 and the other one at 4126 and I want to close one at 4130, the one I want to close is the one that got filled at 4126 and let the other run, but it is closing the one at 4125 and it lets the other one run, is there any way to change this? I try by changing scale in and scale out list in general trade settings but it is the same
[2022-08-17 18:15:54] |
John - SC Support - Posts: 38678 |
In the end, it doesn't matter, the final result will be the same. But, the place to control what you want is the following: Chart Settings: Open Position Average Price (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
