Date/Time: Sun, 16 Mar 2025 15:07:37 +0000
eliminating gap between 2 chart regions
View Count: 642
[2022-08-17 16:55:02] |
MMX - Posts: 119 |
In chart region 1 I have a bar chart and in chart region 2 I have the volume bars. A long time ago I used to be able to eliminate that 4 pixel gap that exists between the 2 chart regions, and the end result would be 1 continuous, uninterrupted vertical grid line from the bottom of chart region 2 to the top of chart region 1. I have since forgotten how I did that and can't find anything on it when trying to find out how to do it. How do I eliminate that gap between the 2 chart regions?
[2022-08-17 17:04:19] |
John - SC Support - Posts: 38678 |
You can not completely eliminate the gap. You can make it less obtrusive, by removing the data line information that shows at the top of each header, but there will always be a small "gap" between the regions where data will not be drawn. To remove the data line information, refer to the setting at the following link and the setting below it: Chart Studies: Subgraphs Tab >> Display Study Name For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-17 17:51:31] |
MMX - Posts: 119 |
Just for your information, the above guidance did fix everything, and I now have continuous uninterrupted vertical grid lines on my charts with no gap whatsoever, none. Thanks.
[2022-08-17 19:22:35] |
Sierra_Chart Engineering - Posts: 18797 |
Also refer to: Chart Settings: Region Data Lines (List) (Chart >> Chart Settings >> Regions >> Region Data Line menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
