Date/Time: Sun, 16 Mar 2025 15:12:37 +0000
Spreadsheet system for Trading
View Count: 434
[2022-08-17 14:00:01] |
User585993 - Posts: 83 |
Is there a way to limit the numbers of trades the system can take in one direction?
[2022-08-17 15:05:48] |
John - SC Support - Posts: 38678 |
You can limit the total quantity of open trades by using the Use Global Trade Position Limit option. Refer to the information here: Global Symbol Settings: Use Global Trade Position Limit For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-17 15:30:33] |
I meant, Can I have the spreadsheet system limit to enter 2 trades in a row in one direction?
[2022-08-17 17:43:03] |
Sierra_Chart Engineering - Posts: 18797 |
You would probably want to use the Position Limit to manage this: Automated Trading Management: MaximumPositionAllowed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
