Date/Time: Mon, 17 Mar 2025 12:14:11 +0000
[Programming Help] - programming question
View Count: 406
[2022-08-17 11:49:36] |
User996274 - Posts: 96 |
I would like to be alerted when an oscillating study changes value by a certain number say "10 or -10" for instance if a oscillating study makes a high or low an alert would be activated if the value of the oscillator retraced by 10 Is this possible? Date Time Of Last Edit: 2022-08-17 13:02:20
[2022-08-17 17:20:07] |
JohnR - User831573 - Posts: 320 |
I would think that is possible. Using ACSIL keep track of the highest high and lowest low values for the last xxx bars of data. Then compare that to the current value. You can also set variables to control the direction of the alert trigger as well as insuring it only fires once in each direction. Highest High/Lowest Low Over N Bars Study/Chart Alerts And Scanning Hope this helps, JohnR Date Time Of Last Edit: 2022-08-17 17:20:41
