Date/Time: Sun, 16 Mar 2025 08:31:18 +0000
DPL showing wildly inaccurate numbers
View Count: 461
[2022-08-17 11:47:15] |
BenjaminR - Posts: 172 |
In an attached trade window, the DPL (C) shows a wildly inaccurate tally. For example... a loss of $100.00, immediately reflects as -$2437.50; however, in checking the back end w/ the broker, the numbers seem to be correct. This problem started yesterday, & at that time, there were some suspicious changes as I toggled back & forth to see what was going on- but let's keep it simple for now, & assume all was correct where it counts. [This is in the ES September contract, btw] Anticipating you'll want a log, I just sent it. Also, yesterday, troubleshooting the problem first, I cleared all the trades in the trade activity log, & also updated Sierra Chart from v. 2422 to v. 2424. Please advise... thank you. |
[2022-08-17 12:24:22] |
Sierra_Chart Engineering - Posts: 18797 |
Refer to the instructions here: Help With Daily Profit/Loss Value: Simplified Steps to Solve Incorrect Daily Profit/Loss Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
