Date/Time: Mon, 22 Jun 2026 23:29:58 +0000
I can't upload a chartbook
View Count: 1295
[2022-08-17 11:44:17]
User707307 - Posts: 84
Here's a chartbook not compatible with the last version, can you please upload it?
Thank you
attachmentES MID ONH AND ONL.cht - Attached On 2022-08-17 11:43:44 UTC - Size: 356.04 KB - 531 views
[2022-08-17 14:12:51]
John - SC Support - Posts: 46822
When we open this Chartbook there are no charts showing up. We do not know if this is an issue with the age of the file or something else. But in the end, we are not able to update this.
Please check your Backups folder to see if you might have a backup of this chartbook in there. Refer to the following:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
[2022-08-17 17:41:22]
Sierra_Chart Engineering - Posts: 24095
This particular Chartbook is very old. We are not even sure what version you would need to open it with. But it would be best to simply to rebuild it.
[2022-08-18 18:50:14]
User873012 - Posts: 3
hello there,i have the same problem that when i want to upload my chartbook it says that chartbook file is not compatible and the file isnt that old or i guess it isnt.its from 2020 or something i believe
could you help me please?
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2022-08-18 18:49:16 UTC - Size: 276.18 KB - 294 views
[2022-08-18 19:03:03]
Attached is the updated chartbook.
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2022-08-18 19:03:00 UTC - Size: 20.43 KB - 297 views
[2022-09-09 07:36:06]
hello, could you please convert my chartbook,it says that chartbook file is not compatible,thank you
attachmentG7FXPROFOOTPRINTCHARTBOOK-200409-002540.Cht - Attached On 2022-09-09 07:35:17 UTC - Size: 528.28 KB - 346 views
[2022-09-09 14:43:49]
attachmentG7FXPROFOOTPRINTCHARTBOOK-200409-002540.Cht - Attached On 2022-09-09 14:43:45 UTC - Size: 44.08 KB - 306 views
