Date/Time: Sun, 16 Mar 2025 08:26:28 +0000
Using Multiple Drawing Tool Configurations
View Count: 420
[2022-08-16 15:22:34]
Thaddeus Fulmer - Posts: 71
I'm attempting to configure different colors for the Zig Zag tool. But whenever I change the configure button, the color stays the same. It appears the configure button is for the line tool. In order to change the color of the ZZ tool, I have to Current tool configure and change from there. I want to be able to switch colors quickly.
[2022-08-16 19:18:58]
John - SC Support - Posts: 38678
The Zig Zag tool is just a series of connected individual lines. Therefore, the tool configurations you want to change/setup are the ones or the Line and then use those for your ZigZag tool.
[2022-08-16 19:32:01]
User459170 - Posts: 262
After changing the color, you need to double click your zig zag line which will bring up the line properties menu, then choose T1, T2, etc. for the different colors you have configured.
