Date/Time: Sun, 16 Mar 2025 08:31:17 +0000
I want to put one of the CBs as a separate window on my second monitor
View Count: 403
[2022-08-16 14:01:51]
zxmmmmmm - Posts: 10
I have two monitors and I want to put one of the CBs as a separate window on my second monitor. How do I do this please? Thanks!
[2022-08-16 17:43:23]
John - SC Support - Posts: 38678
The only way to have a separate Chartbook in another window is to use a second instance of Sierra Chart. The easiest way to do this is to use the option for File >> New Instance. Refer to the information here:
File Menu: New Instance (File)
