Date/Time: Mon, 17 Mar 2025 11:32:02 +0000
Stop loss
View Count: 387
[2022-08-16 10:19:30] |
User575910 - Posts: 16 |
Hi there, will a stop loss order be active on sierra chart if platform is closed?? If you can let me know asap would be appreciated as travelling soon and want to hold an open position with a stop loss order in place Many thanks, Dean |
[2022-08-16 10:37:14] |
Sierra_Chart Engineering - Posts: 18805 |
It depends. If it is for an Open Position, the answer is yes. Since you are using CQG, refer to: Attached Orders: Management of Attached Orders when Trading Service Supports Server Side OCO Only Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-16 14:49:23] |
great, many thanks
