Date/Time: Sun, 16 Mar 2025 08:28:51 +0000
Feature request - ability - 1 action change font on all 17 items in Global Settings Fonts
View Count: 349
[2022-08-15 19:54:54] |
JohnR - User831573 - Posts: 320 |
I recently upgraded to better GPU graphic adapters (Nvidia GTX 1660) and also went to multiple 32" 4K hi res monitors. My request is that there be a way to make 1 change and have it modify all of the 17 possible font items within the global Fonts setting window. This is not necessarily a big deal, E X C E P T ---> I have 5 different SC setups. Futures, Stock & ETFs, Crypto, Dev and Test. So instead of changing 17 items to get from a Seguri 10 or 12 font to something that is readable, it is going to require 85 changes. I would think this would be useful to new users also, having a better out of the box experience My suggestion, is to either add one more line to the font window near the top -> Change font in all areas of SC <- or a better suggestion is to add another button to the bottom that says something like apply to all areas of SC. Hope you consider this. JohnR |
