Date/Time: Sun, 16 Mar 2025 08:31:19 +0000
[User Discussion] - Vwap drawing settings help
View Count: 498
[2022-08-15 19:20:50] |
Jaydtrade - Posts: 88 |
How if possible, am I able to make the deviation lines be drawn at 2,2.5,3? Right now it only draws them in multiples of 2. I only want the first one at 2, then 2.5 and 3. Is this at all possible. See the pictures below.
Date Time Of Last Edit: 2022-08-15 19:31:32
[2022-08-15 19:37:44] |
John - SC Support - Posts: 38678 |
That is not a Sierra Chart study, so we can not help you with that study. The built-in Volume Weighted Average Price allows you to set Standard Deviation bands at any multiplier. Refer to the information here: Volume Weighted Average Price (VWAP) with Standard Deviation Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-16 12:29:05] |
You guys should adopt it, its great.
