Date/Time: Sun, 16 Mar 2025 19:26:14 +0000
moving chart with pointer
View Count: 395
[2022-08-15 18:02:51]
Ulie - Posts: 7
Is there any way to move the chart around (up, down, sideways) with just the pointer used directly on the chart rather than having to go to where prices are to move it up and down.
[2022-08-15 18:29:40]
John - SC Support - Posts: 38678
Yes, but you have to have the Hand tool selected under the Tools menu. Refer to the following:
Chart Drawing Tools: Hand
Note the information in that section for Vertical movement and the setting you need to update for it.
