Date/Time: Sun, 16 Mar 2025 08:33:47 +0000
SPX500 Intraday data not loading
View Count: 389
[2022-08-15 17:56:02] |
User315672 - Posts: 1 |
Hello I have been using SPX500 intraday data from CFD-FXCM. I noticed that the intraday data is not loading from 8-8-2022. When I tried to delete and re-load data, it only loads data till June-7-2022. I tried everything possible, but not able to get this one working. HELP please? Regards Srinivas Akarapu |
Attachment Deleted. ![]() |
[2022-08-15 18:47:59] |
Sierra_Chart Engineering - Posts: 18797 |
This issue is resolved. Follow the instructions here to download the missing data: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
