Date/Time: Sun, 16 Mar 2025 19:31:22 +0000
multiple charts
View Count: 373
[2022-08-15 17:29:00]
User411320 - Posts: 303
how can I view 2 charts on one screen? so I don't have to go back and forth
[2022-08-15 18:20:40]
John - SC Support - Posts: 38678
You can un-maximize the charts and then place them wherever you like within the graphics area of the Sierra Chart software, or you can use the Tile options to set them up a specific way. Refer to the following:
Chartbooks (Workspaces): Arranging Open Charts in a Chartbook
Another option is to "Detach" one or more of the charts you want such that they are not contained within the Sierra Chart window itself, but are part of your general Windows desktop. You can then size and place them wherever you want. Refer to the following:
Detaching and Attaching Chart Windows: Detaching a Chart
