Date/Time: Sun, 16 Mar 2025 08:31:19 +0000
1-Minute bars not closing at the right time
View Count: 392
[2022-08-15 16:27:20] |
User395685 - Posts: 33 |
Hi, My 1-minute bars are closing at :36 (seconds) instead of :00. Look at the clock (which is right) and the countdown (seconds remaining). I have no idea why, it never happened before and I think I didn't do anything. Thanks for your help. |
[2022-08-15 17:20:41] |
John - SC Support - Posts: 38678 |
If the clock you have up is the "Real-Time Clock", then what you are seeing is just a difference in the time on your computer versus the time of the exchange. Refer to the following: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating: Setting Computer System Date-Time and Time Zone For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-15 17:37:53] |
Thank you, it was the time on my computer that was delayed.
