Date/Time: Sun, 16 Mar 2025 08:28:51 +0000
Spread error
View Count: 467
[2022-08-15 15:31:02]
User933209 - Posts: 38
Hello. I am trying plot a spread on a DOM that goes by: 4*{F.US.TUAU22}-1*{F.US.TYAU22}
Though I am given an error, "Symbol is invalid during SubscribetosymbolDom"
[2022-08-15 16:11:46]
John - SC Support - Posts: 38678
Make sure you have gone through all of the instructions for setting up a Custom Calculated Symbol at the following link (particularly setting the "Uses Formula Operators" set to "Yes"):
Custom Calculated Symbols: Instructions
Also, make sure that F.US.TUA and F.US.TYA are valid symbols for CQG.
[2022-08-15 20:05:12]
Thank you. The issue was that I did not have "Uses Formula Operators" set to "Yes." Though, I do not have any market depth limit orders showing. I only see price fluctuation with traded volume beside it.
[2022-08-15 20:11:32]
You will not get any market depth data with a custom calculated symbol, as there is not really a defined way to do that.
[2022-08-15 20:37:36]
So I assume switching to TT's API would change anything right? As it is possible using TT's AutoSpreader using TT's platform.
[2022-08-16 04:02:19]
Sierra_Chart Engineering - Posts: 18797
We do not understand the question. If you want to use TT, go ahead. That does not involve Sierra Chart.
Date Time Of Last Edit: 2022-08-16 04:02:27
