Date/Time: Sun, 16 Mar 2025 08:28:53 +0000
Scaling A Position - Simple Bracket
View Count: 501
[2022-08-15 15:20:55]
User143450 - Posts: 12
I like using the scaling method when entering a position. However, how do I keep each trade separate? I dont like how early orders are executed when I've placed orders after. For example say I enter a long trade @ 100.01. As it moves up I want to add more so I add again at 100.15 with a stop @ 100.01. If the stop to the second entry gets hit, Sierra treats that stop as the initial trade I entered @ 100.01. This is very frustrating. I want to have each trade stick to its own brackets
[2022-08-15 16:04:31]
John - SC Support - Posts: 38678
If you want to have separate brackets for your orders, then you want to turn OFF the Scale In feature. Refer to the following:
Attached Orders: Scaling In
Just be aware that there is only 1 position line that will give the average price of your open positions. Refer to the following:
Trading Information Windows: How Average Price for Positions Is Calculated and Used
