Date/Time: Sun, 16 Mar 2025 08:26:29 +0000
When I start a new instance of Sierra the futures assets do not have the [M] symbol
View Count: 360
[2022-08-15 13:39:47] |
User472520 - Posts: 7 |
Hi I managed to connect to Denali Exchange however when I start a new instance of Sierra the futures assets do not have the [M] symbol next to it while the main one does. Could you kindly assist. Regards Matthew |
[2022-08-15 15:05:34] |
John - SC Support - Posts: 38678 |
Yes this does make sense and is documented here: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Source of Data for Sub Instances For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
