Date/Time: Tue, 26 Nov 2024 14:40:30 +0000
DOM gap
View Count: 1049
[2014-05-12 10:02:08]
usersc - Posts: 14 Invalid SC Account Name.
I have several gap that appear and disappear in DOM, see picture below.
I use TTnet and 1135 version.
image1.jpg / V - Attached On 2014-05-12 09:57:35 UTC - Size: 76.61 KB - 415 views
image11.png / V - Attached On 2014-05-12 09:57:44 UTC - Size: 13.67 KB - 382 views
[2014-05-12 16:10:46]
What symbol are these Trade DOMs for?
Does the depth correct itself when you select File >> Disconnect and then File >> Connect to Data Feed.
[2014-05-12 19:11:48]
FESX euro stoxx
I already tried but this had not solved the issue, gap isn't permanent, he appear erratically.
[2014-05-12 21:17:12]
We believe this is a problem on the TT FIX adapter side and not something we have control over.
