Date/Time: Sun, 16 Mar 2025 22:36:07 +0000
Access to OMXS30 and Stocks from Sweden
View Count: 612
[2022-08-15 11:59:33]
aso - Posts: 3
Hi
Hello
I have activated my trial period but I cannot access OMXS30.
How do I access the data?
[2022-08-15 15:03:08]
John - SC Support - Posts: 38678
We do not have data for that exchange. If you will be connecting your Sierra Chart to CQG, Rithmic, or Interactive Brokers, then you can see if you can get the data from them.
Or you can try IQ Feed, refer to the information here:
DTN IQ Feed Data Service
[2022-08-16 06:30:47]
aso - Posts: 3
Okay i will try to read more about Interactive Brokers.
I have some questions about the subscriptions.
If i whant live data how much is the cost per month? And it icludes wich exchanges without requirement for trade account?
The delay data is 33$ per month right after the trial period, right?
[2022-08-16 17:06:34]
First, the delayed streaming data that we have available is at no cost and works as long as you have an active Sierra Chart package. The delayed streaming data is available for the CME Group, EUREX, CFE, and NASDAQ TotalView exchanges.
The only exchange that requires a trading account is the CME Group, in order to get the data at the non-professional rates. You can always pay the Professional rates, but there are other options available to get an account for a small layout of funds. Refer to the information here:
Easy Solution to CME Funded Trading Account Requirement
Second, the exchanges that are available with the Denali Exchange Data Feed along with their costs can be found at this link:
Denali Exchange Data Feed: Supported Exchanges (Exchange Fees)
If you are interested in Indices or US Equities, then those are part of our Sierra Chart Exchange Data Feed. Refer to the information at the following link for what is available through this option:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SupportedExchanges
[2022-08-29 09:25:55]
aso - Posts: 3
Okay sounds good.
What about AMP? They have sierra chart as trading plattform.
So the data i will pay Sierra chart and the account will be with a broker to access live data for non professional? Is that right?
Wich broker do you recommend?
[2022-08-29 15:27:31]
You can use AMP as a broker and connect your Sierra Chart to that account in order to qualify for the CME Group Non-Professional fees.
In terms of our recommendation, it is not about specific brokers as about the underlying order routing service. In this case, we recommend our Teton Order Routing Service which has support from a list of brokers found at Step #2 of the Setup Instructions here:
Sierra Chart Teton Futures Order Routing: Setup Instructions
