Date/Time: Sun, 16 Mar 2025 08:21:37 +0000
Advanced settings
View Count: 514
[2022-08-15 11:35:50] |
User707307 - Posts: 84 |
Hello, I want to go to advanced settings. But I can't find it. Where do I have to go? Thank you |
[2022-08-15 11:56:38] |
Sierra_Chart Engineering - Posts: 18797 |
The Advanced Settings tab of the Chart Settings window has been replaced in the newer Chart Settings window. Refer to the documentation here for all of the settings and where they can be found in the new Chart Settings window: Chart Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
