Date/Time: Sun, 16 Mar 2025 08:21:37 +0000
Change of ticks per VOlume BAR
View Count: 810
[2022-08-15 10:33:08] |
User707307 - Posts: 84 |
Hello, I am trying to change on the attached chart the ticks per volume bar of the profile, for some reason it's stucked to 5, I try to change it TO 1 or 2. And it goes back to 5 everytime I click to apply. What can be the reason for this? Thank you. |
![]() Attachment Deleted. |
[2022-08-15 11:14:43] |
Sierra_Chart Engineering - Posts: 18797 |
This is explained in the documentation: Volume By Price Study: Ticks Per Volume Bar You need to set this setting to 1: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
