Date/Time: Sun, 16 Mar 2025 19:19:23 +0000
Download data
View Count: 341
[2022-08-15 10:11:58] |
User707307 - Posts: 84 |
Hello, I have the same settings for all charts, and for some reason on the chart attached I can't see the correct data for as many days as I want, and then the 200MA is not shown. What can be the reason for this? Thank you |
[2022-08-15 11:17:34] |
Sierra_Chart Engineering - Posts: 18799 |
You need to set that chart to a Continuous Futures Contract chart: Continuous Futures Contract Charts Also refer to: Chart Studies: Resolving Study Not Visible Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
