Date/Time: Sun, 16 Mar 2025 08:24:09 +0000
Can't draw extended area
View Count: 406
[2022-08-15 07:21:55]
Amelyn - Posts: 46
Ever since the new update 2422 I cannot draw an extended area. I select it, try to draw, nothing happens on the chart.
The hand tool is my default setting and nothing has been changed on my end. No issues until now. Really losing my patience with these updates.
[2022-08-15 09:05:36]
Sierra_Chart Engineering - Posts: 18797
This is not making sense.
What Drawing Tool are you selecting? It is not a problem in the newer version.
However, check this particular setting because after an update it may not be set correctly:
Chart Drawing Tools: After Single Tool Use Change To (Global Settings >> Tool Settings >> General >> Tool Options)
Date Time Of Last Edit: 2022-08-15 09:05:53
