Date/Time: Tue, 26 Nov 2024 14:36:39 +0000
Retrieve Intraday data
View Count: 1038
[2014-05-12 09:04:25] |
User75439 - Posts: 18 |
Hi, is there a way I can retrieve historical Intraday price action and market internals (Looking for intra day advance decline + ticks) since 01.01.2013 ? |
[2014-05-12 09:36:28] |
Yes you can. Use the Sierra Chart Historical Data service: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html These are the following symbols to use: $TICK (For NYSE) $NSHF (For NYSE) Make sure to follow the instructions in help topic 42.1 to get historical data as far back as you need: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-12 10:36:29] |
How can I split the chart, with Horizontal line / zone, to RTH and non regular session. Looking at equity futures indices |
[2014-05-12 17:18:42] |
We assume you mean a vertical line. We recommend using the Vertical Grid in Chart >> Chart Settings. You will want to set it to Session Start. Here is the documentation: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#VerticalGridLinesAtEvery Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-12 17:19:31
