Date/Time: Sun, 16 Mar 2025 08:24:10 +0000
Get candlestick values
View Count: 932
[2022-08-14 22:45:26] |
User191934 - Posts: 1 |
How do I get candlestick values for individual candles (H-L-C). The Chart Values Windows just has the values for the last candle. I would have thought I could hover over the candle and the info bar at the top of the chart would update as I moved my mouse from bar to bar.
[2022-08-15 09:07:29] |
Sierra_Chart Engineering - Posts: 18797 |
Refer to the Chart Values tool: Chart Drawing Tools: Chart Values/Crosshair Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
