Date/Time: Sun, 16 Mar 2025 08:21:37 +0000
Huge space between indicators
View Count: 394
[2022-08-14 20:30:35] |
User707307 - Posts: 84 |
Hello, On the picture attached, I am trying to make the cumulative delta indicator. The indicator below, it uses most of the screen size, How can I change the size of that? Thank you |
[2022-08-15 09:10:02] |
Sierra_Chart Engineering - Posts: 18797 |
Refer to: Working With Charts: Chart Window and Regions And refer to: Chart Scale and Scale Adjusting: Interactive Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-15 09:10:30
