Date/Time: Sun, 16 Mar 2025 08:28:51 +0000
Change colors
View Count: 375
[2022-08-14 19:51:37]
User707307 - Posts: 84
I have been trying to change the color of the info of the profiles on the picture attached, and I can't find it. How can I do that?
Thank you
imagePROFILE LETTERS.png / V - Attached On 2022-08-14 19:50:34 UTC - Size: 27.24 KB - 103 views
[2022-08-15 10:19:05]
Sierra_Chart Engineering - Posts: 18797
This is controlled with the "Chart Text" color set through Graphics Settings:
Graphics Settings
[2022-08-15 11:24:13]
I just checked that, and the "CHART TEXT" option, doesn't change the text of the picture, it changes some text on the chart, but not the info box of the profile.
Where can I find that?
Thank you
[2022-08-15 11:55:52]
Attach that chart by following these instructions:
[2022-08-15 15:01:00]
John - SC Support - Posts: 38678
We do not need your chart.
You can change the color of that text by changing the color for Subgraph 7 (SG7). Refer to the information here:
Volume By Price Study: Volume Numbers Text Color and Size (SG7)
