Date/Time: Sun, 16 Mar 2025 08:26:29 +0000
Previous close line
View Count: 749
[2022-08-14 14:16:33]
User707307 - Posts: 84
I am using the precious close line indicator to show the previous closes, but I FOUND OUT the indicator only show one day. I want it to track all days and use that as a line that when it is touched, it closes. Like a "naked close"
How can I do that?
Thank you
[2022-08-15 14:33:25]
John - SC Support - Posts: 38678
There is not a built-in study that will do exactly what you want.
But, first look at the Daily OHLC study which will allow you to display a line for the previous close across that day, or you can display them all the way across the chart by changing the draw style, but there is not an option for stopping when it intersects a bar. You will want to set the Reference Days Back to 1 to get the previous day's close. Refer to the information here:
Daily OHLC
To get what you want, you would have to program a custom study or have someone program it for you. Refer to the information on our interface language starting here:
Advanced Custom Study Interface and Language (ACSIL): Introduction
