Date/Time: Sun, 16 Mar 2025 08:21:38 +0000
TPO Scaling too small
View Count: 562
[2022-08-14 03:50:42]
Justin Taft - Posts: 6
Hello, I have been fussing with the TPO for a phew days and just can't seem to get my TPO data to scale so I can read it.
I am currently using the trial and have tied to pull up the following symbols
QQQ-NQTV, ESU22-CME and TSLA-NQTV
I have tried to change charts scaling along with TPO scaling and came close when I put in a custom range, but this then made the data too high
I have attached an image of the view I currently have.
I have been searching forum as well as reading through Siearra Charts documentaion and have not been able to resolve.
Any help would be greatly appreciated!
imageTPO_View.jpg / V - Attached On 2022-08-14 03:47:18 UTC - Size: 52.15 KB - 144 views
[2022-08-14 11:10:38]
Sierra_Chart Engineering - Posts: 18797
Refer to the instructions here for this:
Time Price Opportunity (TPO) Profile Charts: Solving Overlapping TPO Letters
We would recommend setting the Letter/Block Price Increment in Ticks Input to 20. You may need to go even higher or lower.
Date Time Of Last Edit: 2022-08-15 16:43:59
[2022-08-14 13:23:37]
Thank You for the quick response!
Increasing the Letter/Block Price Increment in Ticks, solved the problem!
This was super helpful.
Thank You!
