Date/Time: Mon, 17 Mar 2025 12:14:11 +0000
Not functioning
View Count: 359
[2022-08-13 17:36:05]
User862932 - Posts: 1
Not Connected: I tried to follow instructions I have no Disconnect button only connect Button
Also free trial said only one day???????? and I just started trial?
[2022-08-14 11:15:04]
Sierra_Chart Engineering - Posts: 18805
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
For further information, refer to:
Sierra Chart Trial Account
