Date/Time: Sun, 16 Mar 2025 08:28:53 +0000
changing symbol through typing not possible on newer versions?
View Count: 350
[2022-08-13 12:53:38]
Tomas21 - Posts: 23
I have several versions of sierra on my pc , on the newer version of sierra I can't change the stock symbol on a chart by typing the new symbol ( + enter ) , ( I can still do this on the older version ??
[2022-08-15 13:59:58]
John - SC Support - Posts: 38678
This should not have changed, but check the setting for Global Settings >> General Settings >> Charts >> Symbol >> Support Symbol Entry from Chart Window and ensure that is set to Yes in the newer versions on your system.
