Date/Time: Fri, 11 Sep 2026 12:26:16 +0000
stop orders
View Count: 2047
| [2022-08-12 19:22:25] |
| sierrac1 - Posts: 20 |
is there a way to place a stop/ limit order by holding a key and placing the order whith a mouse click , so the order is placed where the cursor is?
| [2022-08-12 19:33:15] |
| Tom_Tom - Posts: 52 |
I do this by a right mouse click on your point on the chart, than a menu pops up. you can choose limit order and anything else. i think you must turn on chart trading in the trade menu.
| [2022-08-12 19:43:56] |
at the moment i do it like that as well ? but thats just slower , and if there is a drawing on the price where u want to place the order , it wont work since ur clicking on the drawing
| [2022-08-12 19:55:07] |
I know what you mean, but i never have seen such a mechanic in sierra chart. to place a order, sorry.
| [2022-08-12 21:12:51] |
| User459170 - Posts: 262 |
You can click the far right of the drawing (away from it) and place the order. Date Time Of Last Edit: 2022-08-12 21:14:07
| [2022-08-13 17:41:46] |
https://prnt.sc/UO9fpn3fC4jd doesnt work
| [2022-08-13 19:45:41] |
Looks like your screenshot has the order options in the menu. What doesn't work? The cross hair seems to be missing though to track to the price. Perhaps you need need to change the color of the cross hair. Date Time Of Last Edit: 2022-08-13 19:48:03
| [2022-08-13 20:56:28] |
i clicked far right , as u said, i right clicked on the line but the trading menu dindt pop up
| [2022-08-13 23:06:26] |
trading menu can been seen in the second column of the popup (chart shortcut menu) in your screenshot. You can organize the order in which things appear in your pop up (chart shortcut menu) and also remove what is not needed by checking or unchecking menu itemsGlobal Settings Menu: Customize Chart Shortcut Menu (Global Settings menu) Global Settings Menu: Customize Chart Trade Menu (Global Settings menu) Date Time Of Last Edit: 2022-08-14 01:58:21
| [2022-08-14 15:14:35] |
| Sierra_Chart Engineering - Posts: 24828 |
Regarding the first post, refer to this Chart Setting: Chart Settings: Extend Chart DOM Across Entire Chart When Using Ctrl(Buy) / Shift(Sell) (Chart >> Chart Settings >> Trading menu) Also refer to: Global Settings Menu: Customize Chart Trade Menu (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-14 15:15:32
| [2022-08-15 12:42:37] |
Hi, yes thats right! You can use the Trading Chart DOM, to set Limit and Stop Orders, by ONE Mouse Click. Left Click for Limit Order and Right Click for Stop Order. So this would be the mechanic you can use. If i do this by this way i turn on the Chart Values/Crosshair. |
