Date/Time: Thu, 19 Sep 2024 22:03:49 +0000
Discrepancy in Daily FXCM chart
View Count: 1190
[2014-05-12 00:42:36] |
cmb999 - Posts: 211 |
Hello, looking at AUD/NZD. It seems the intraday highs do not correspond to the highs on the daily chart For 5/8, 5/9, and 5/11, the intraday highs are: 1.08723, 1.08722, 1.08699, a steady decrease. the daily chart shows a steady increase, 1.08723, 1.08735, 1.08744 http://www.sierrachart.com/image.php?l=1399855140356.png http://www.sierrachart.com/image.php?l=1399855236552.png Date Time Of Last Edit: 2014-05-12 00:45:19
[2014-05-13 06:20:55] |
Yes. We can confirm these are the values provided by FXCM. We do not have an explanation for this. We re-downloaded the historical Daily data direct from FXCM and got the same daily high values for those dates. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-13 06:21:12
