Date/Time: Sun, 16 Mar 2025 08:24:07 +0000
VIX - Trade - IBKR - 'EtradeOnly'-Error
View Count: 542
[2022-08-12 18:56:18] |
Tom_Tom - Posts: 40 |
Hello, today i would send a Bracket Order for the VIX to IBKR. But i always get a error. The log says something about: The 'EtradeOnly' order attribute is not supported. I use the VXU22_FUT_CFE [CV][M] Symbol. Do you know something about this issue? Thanks Tom |
[2022-08-12 19:40:15] |
John - SC Support - Posts: 38678 |
That is not the correct symbol for Interactive Brokers. You would need to use a Trade and Current Quote Symbol in order to get the data for the CFE from us and then trade it properly through Interactive Brokers. But, due to Interactive Brokers complex symbology, we do not know exactly what the correct symbol would be. Refer to the following information we have, but you may be best off to just call and ask them: Interactive Brokers Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-12 20:55:24] |
Hello, know for the Symbol: VXMU22_FUT_CFE i have used in Trade and Current Quote Symbol (Action): VXM-202209-CFE-USD Now the Bracket Order will be sent to IBKR. Thanks! Regards Tom |
