Date/Time: Sun, 16 Mar 2025 08:21:37 +0000
QuoteBoard
View Count: 1342
[2022-08-12 17:01:38] |
Anthonia Solomon - Posts: 3 |
I am new to this SierraChart. I want to see my QuoteBoard. i closed it , how do i make it appear. Thanks |
[2022-08-12 17:50:22] |
John - SC Support - Posts: 38678 |
Select File >> New Quote Board. If you saved your list of symbols, then you can reimport them by selecting Symbols on the Quote Board window then Import on the new window that opens, then select your list. Otherwise, you will have to redo the setup. If you want your quote board readily available, you will not want to close it. Keep it open when you save your chartbooks and it will come back up when you open them. Refer to the information on Quote Boards here: Getting Quotes: Quote Board For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
