Date/Time: Sun, 16 Mar 2025 08:31:19 +0000
i forgot to log out from my home pc
View Count: 659
[2022-08-11 19:43:57]
coachted - Posts: 381
I forgot to logout from my home pc and am away for a week and want to use my laptop how do i log out from the home pc remotely
[2022-08-11 20:21:50]
John - SC Support - Posts: 38678
There is not a way to do this remotely. You would have to have someone disconnect your home PC for you.
[2022-08-12 12:47:08]
User150671 - Posts: 69
I believe you can reset your Sierra Chart Password and that will de-authenticate any current open connections allowing you to reconnect with the new password.
Pretty sure I have done this before.
[2022-08-12 14:55:42]
Sierra_Chart Engineering - Posts: 18797
You can use Sierra Chart on two or three computers at the same time.
So you are certainly not getting blocked in that regard. Maybe you are having problems with an external service connection like CQG which we see you are using but we have no control over that.
Date Time Of Last Edit: 2022-08-12 14:55:56
[2022-08-12 14:58:07]
i had someone j=shutdown my pc...it was definitley the data provider
