Date/Time: Sun, 16 Mar 2025 08:24:09 +0000
Function Keys
View Count: 413
[2022-08-11 19:14:16] |
User672422 - Posts: 9 |
The Control Bar buttons keep getting untoggled. Example; If the "Hand" button on the Control Bar is toggled and then I toggle the "Price Retrc" button on the same Control Bar to draw a retracement, the "Hand" function button becomes untoggled. Effectively, this renders all other functions inoperable until one is selected. It used to keep the "Hand" button toggled. This behavior started after I updated the software to Revision 43083 yesterday Thank you Jokie |
[2022-08-11 20:14:10] |
John - SC Support - Posts: 38678 |
We are not sure if your issue is related to a problem we had in version 2422, in which the option for "Tools >> Tool Settings >> After Single Tool Use Change To" was blanked out. Therefore, the first thing we need for you to do is to update to the Pre-Release, which is v 2423 as this has this issue fixed. But, in general, when you are using tools on the Control Bar, when you have a specific tool selected, the other tools are not going to stay selected. So what you are stating would be the correct way of it working. The above situation would just have the Hand tool come back to being active after you used another one. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-14 12:54:43] |
John - Updating to the Pre-Release Version 2423 did fix the issue. Thank you Jokie |
