Date/Time: Sun, 16 Mar 2025 08:33:46 +0000
Need SC Exchange Data Feed And Teton Feed Simultaneously
View Count: 384
[2022-08-11 18:12:59] |
User732740 - Posts: 23 |
Also, are the DOW Indexes no longer available?
[2022-08-11 19:09:55] |
John - SC Support - Posts: 38678 |
It is not a problem to have both the Sierra Chart Exchange Data Feed and the Denali Exchange Data Feed at the same time. Refer to the following: https://www.sierrachart.com/index.php?page=doc/RealTimeDataFeedsAvailableFromSierraChart.php#UsingBothDenaliExchangeDataFeedAndSierraChartExchangeDataFeed With regards to the DOW Indices, we will have to check on that. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-12 10:41:57] |
Sierra_Chart Engineering - Posts: 18797 |
The Dow Jones indices is now listed again. You can now activate it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-12 10:42:09
