Date/Time: Sun, 16 Mar 2025 13:53:02 +0000
mouse does not revert to original state
View Count: 638
[2022-08-11 14:14:20] |
User427561 - Posts: 217 |
mouse poiter does not revert to original state(hand) after any action sch as movind=g a line, uaing version 2422. any help to have the mouse returb to original state(hand) after any actio?n mouse alwayss return to pointr vs hand
[2022-08-11 14:58:36] |
John - SC Support - Posts: 38678 |
This was an oversight in version 2422. Please update to the Pre-Release version 2423 where this is resolved. Then check the setting for Tools >> Tool Settings >> General >> After Single Tool Use Change To and make sure it is set as you desire.
[2022-08-16 13:29:22] |
mouse problem seems returning in version 2424
Date Time Of Last Edit: 2022-08-16 13:30:35
[2022-08-16 22:13:59] |
Sierra_Chart Engineering - Posts: 18797 |
Again check this setting and set it as you require: Tools >> Tool Settings >> General >> After Single Tool Use Change To Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-17 14:33:17] |
version 2423 now running 2424
version 2423works best now running 2424
Date Time Of Last Edit: 2022-08-17 14:46:05
[2022-08-17 14:37:43] |
sorry mous revert only when other tool is line study but not if it is a stationry text
[2022-08-17 15:25:21] |
When we set the option for After Single Tool Use Change to to Hand and then use the Stationary Text tool, it properly changes to the Hand tool after completing the Stationary Text drawing. If you are having a different experience, then please give us more information on the exact workflow so we can try and reproduce it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-17 18:22:13] |
its not thr te chrte charyext content thst is thr problrm. theproblem occurs wnen I change the text location on the chart
[2022-08-17 19:33:25] |
Moving a drawing (including Stationary Text) will not cause a change in the tool being used at that time. If this does not answer your question, then please give us the exact steps you are taking and when the issue arises and how it manifests. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
