Date/Time: Mon, 17 Mar 2025 11:32:02 +0000
[Programming Help] - Ascil SecondaryColor doesn't work
View Count: 432
[2022-08-11 08:44:39] |
BenjFlame - Posts: 335 |
I expected to implement this in a few minutes and it's been hours i'm on this and now posting on this board. Wherever SecondaryColor is implemented in this code it is completely ignored on the chart. I implemented this on numerous studies in exact same way and always had it working. Why on earth is it not working this time? The SubGraph_currentDeltaText is set with DRAWSTYLE_TEXT_WITH_BACKGROUND so it should work. /*============================================================================ 1 second chart delta on single line. ----------------------------------------------------------------------------*/ SCSFExport scsf_ShortTimeFrameDelta(SCStudyInterfaceRef sc) { // Graphs SCSubgraphRef Subgraph_currentDelta = sc.Subgraph[0]; SCSubgraphRef SubGraph_Price_Line = sc.Subgraph[1]; SCSubgraphRef SubGraph_currentDeltaText = sc.Subgraph[2]; SCSubgraphRef SubGraph_topBb = sc.Subgraph[3]; SCSubgraphRef SubGraph_BottomBb = sc.Subgraph[4]; // Inputs SCInputRef Input_StudyId_Delta = sc.Input[0]; SCInputRef Input_SubgraphId_delta = sc.Input[1]; SCInputRef Input_StudyId_BBtop = sc.Input[2]; SCInputRef Input_SubgraphId_BBtop = sc.Input[3]; SCInputRef Input_StudyId_BBbotom = sc.Input[4]; SCInputRef Input_SubgraphId_BBbotom = sc.Input[5]; SCInputRef Input_StudyId_OffsetPositiveDelta = sc.Input[6]; SCInputRef Input_SubgraphId_OffsetNegativeDelta = sc.Input[7]; if (sc.SetDefaults) { // Set the defaults sc.MaintainAdditionalChartDataArrays = 0; sc.CalculationPrecedence = LOW_PREC_LEVEL; sc.GraphName = "SHORT TIMEFRAME DELTA"; sc.GraphRegion = 0; sc.ScaleRangeType = SCALE_SAMEASREGION; sc.AutoLoop = 1; // Graphs Subgraph_currentDelta.Name = "Current Delta"; Subgraph_currentDelta.DrawStyle = DRAWSTYLE_HIDDEN; SubGraph_Price_Line.Name = "Price Color"; SubGraph_Price_Line.DrawStyle = DRAWSTYLE_COLOR_BAR_CANDLE_FILL; SubGraph_Price_Line.LineWidth = 6; SubGraph_currentDeltaText.Name = "Current Delta Text"; SubGraph_currentDeltaText.DrawStyle = DRAWSTYLE_TEXT_WITH_BACKGROUND; SubGraph_currentDeltaText.PrimaryColor = RGB(255, 255, 255); SubGraph_currentDeltaText.LineWidth = 12; SubGraph_currentDeltaText.GraphicalDisplacement = 2; SubGraph_topBb.Name = "Top Bollinger Band"; SubGraph_topBb.DrawStyle = DRAWSTYLE_HIDDEN; SubGraph_BottomBb.Name = "Top Bollinger Band"; SubGraph_BottomBb.DrawStyle = DRAWSTYLE_HIDDEN; // Inputs Input_StudyId_Delta.Name = "Delta ref study Id"; Input_StudyId_Delta.SetInt(10); Input_SubgraphId_delta.Name = "Delta ref subgraph Id"; Input_SubgraphId_delta.SetInt(3); Input_StudyId_BBtop.Name = "BBtop ref study Id"; Input_StudyId_BBtop.SetInt(11); Input_SubgraphId_BBtop.Name = "BBtop ref subgraph Id"; Input_SubgraphId_BBtop.SetInt(0); Input_StudyId_BBbotom.Name = "BBbottom ref study Id"; Input_StudyId_BBbotom.SetInt(11); Input_SubgraphId_BBbotom.Name = "BBbottom ref subgraph Id"; Input_SubgraphId_BBbotom.SetInt(2); Input_StudyId_OffsetPositiveDelta.Name = "Offset positive Delta"; Input_StudyId_OffsetPositiveDelta.SetInt(4); Input_SubgraphId_OffsetNegativeDelta.Name = "Offset negative Delta"; Input_SubgraphId_OffsetNegativeDelta.SetInt(-2); return; } // Only draw projection on current bar // Make sure it is added after moving average calculations, or any calculation that will produce array values needed to be used over several bars back. if (sc.Index != sc.ArraySize - 1) { return; } // Top BB SCFloatArray topBB; if (sc.GetStudyArrayUsingID(Input_StudyId_BBtop.GetInt(), Input_SubgraphId_BBtop.GetInt(), topBB) >= 0 && topBB.GetArraySize() > 0) { SubGraph_topBb[sc.Index] = topBB[sc.Index]; } // Bottom BB SCFloatArray bottomBB; if (sc.GetStudyArrayUsingID(Input_StudyId_BBbotom.GetInt(), Input_SubgraphId_BBbotom.GetInt(), bottomBB) >= 0 && bottomBB.GetArraySize() > 0) { SubGraph_BottomBb[sc.Index] = bottomBB[sc.Index]; } // Get delta SCFloatArray delta; if (sc.GetStudyArrayUsingID(Input_StudyId_Delta.GetInt(), Input_SubgraphId_delta.GetInt(), delta) >= 0 && delta.GetArraySize() > 0) { Subgraph_currentDelta[sc.Index] = delta[sc.Index]; } // Delta text SCString deltaText; deltaText.Format("%.0f", Subgraph_currentDelta[sc.Index]); SubGraph_currentDeltaText.TextDrawStyleText = deltaText; // Normal positive if (Subgraph_currentDelta[sc.Index] > 0 && Subgraph_currentDelta[sc.Index] < SubGraph_topBb[sc.Index]) { SubGraph_currentDeltaText.DataColor[sc.Index] = RGB(27, 188, 155); SubGraph_currentDeltaText.SecondaryColor = RGB(0, 0, 0); SubGraph_currentDeltaText[sc.Index] = sc.Close[sc.Index] + Input_StudyId_OffsetPositiveDelta.GetInt(); } // High positive else if (Subgraph_currentDelta[sc.Index] > 0 && Subgraph_currentDelta[sc.Index] > SubGraph_topBb[sc.Index]) { SubGraph_currentDeltaText.DataColor[sc.Index] = RGB(250, 250, 110); SubGraph_currentDeltaText.SecondaryColor = RGB(0, 0, 0); SubGraph_currentDeltaText[sc.Index] = sc.Close[sc.Index] + Input_StudyId_OffsetPositiveDelta.GetInt(); } // Normal negative else if (Subgraph_currentDelta[sc.Index] < 0 && Subgraph_currentDelta[sc.Index] > SubGraph_BottomBb[sc.Index]) { SubGraph_currentDeltaText.DataColor[sc.Index] = RGB(188, 27, 60); SubGraph_currentDeltaText.SecondaryColor = RGB(0, 0, 0); SubGraph_currentDeltaText[sc.Index] = sc.Close[sc.Index] - Input_SubgraphId_OffsetNegativeDelta.GetInt(); } // High negative else if (Subgraph_currentDelta[sc.Index] < 0 && Subgraph_currentDelta[sc.Index] < SubGraph_BottomBb[sc.Index]) { SubGraph_currentDeltaText.DataColor[sc.Index] = RGB(224, 163, 255); SubGraph_currentDeltaText.SecondaryColor = RGB(0, 0, 0); SubGraph_currentDeltaText[sc.Index] = sc.Close[sc.Index] - Input_SubgraphId_OffsetNegativeDelta.GetInt(); } else { SubGraph_currentDeltaText.DataColor[sc.Index] = RGB(255, 255, 255); } int& PriorArraySize = sc.GetPersistentInt(1); if (sc.Index == 0) { PriorArraySize = sc.ArraySize; } if (PriorArraySize < sc.ArraySize) { Subgraph_currentDelta[sc.Index - 1] = 0; SubGraph_currentDeltaText[sc.Index - 1] = 0; } PriorArraySize = sc.ArraySize; } Date Time Of Last Edit: 2022-08-11 08:46:21
[2022-08-11 09:42:59] |
DRAWSTYLE_TEXT_WITH_BACKGROUND was ignored by default setting of study that used TEXT draw style. Changing the default study to Text with background fixed the issue. Date Time Of Last Edit: 2022-08-11 09:44:05
