Date/Time: Sun, 16 Mar 2025 08:33:47 +0000
Volume Multiplier
View Count: 541
[2022-08-11 07:34:03]
Nkrastins - Posts: 35
where is this feature on the newest version?
Btw, can you please return to that format for chart settings?
The new one so inconvenient...
imageCapture.PNG / V - Attached On 2022-08-11 07:32:40 UTC - Size: 42.62 KB - 133 views
[2022-08-11 10:04:54]
Sierra_Chart Engineering - Posts: 18797
This is on the "Symbol" tab of the Chart Settings window:
Chart Settings: Volume and Open Interest Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
No we do not worship Microsoft evil:
Refer to:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NewChartSettingsWindow
Date Time Of Last Edit: 2022-08-11 10:06:52
[2022-08-11 14:36:39]
John - SC Support - Posts: 38678
Also be aware of the Search option at the top of the Chart Settings window, so you could just type in "Volume" and get the listing of all the chart settings that have the word "Volume" in them, then select the one you want to go to that setting.
[2022-08-11 14:43:24]
Yes here is the documentation for searching for settings:
Settings Windows Interface: Searching for Specific Settings
