Date/Time: Sun, 16 Mar 2025 08:33:46 +0000
[User Discussion] - Splitting Load Over Multiple Instances, Overlaying Studies from Other Instances
View Count: 329
[2022-08-11 03:14:09] |
User379468 - Posts: 508 |
Using multiple instances to split the CPU load. Execution in one instance, intraday charts spread over a couple instances, daily charts in another instance. Within the intraday instances, also use watchlists to switch between instruments to reduce load from having charts for all symbols open simultaneously. ie, ES, YM, RTY, NQ all go under one 'Indices' chartbook, and switch between them as needed. Considering this, is there any creative/smart way to overlay indicators/MA's from daily charts onto intraday charts? Any ideas on most resource efficient solutions? |
